turbo timer install
378 Views 1 Reply 2 Participants Last post by  MeTrzan
ok, i ran about 10 searches on how to install a turbo timer and still can't figure it out. i can't even find where the harness is supposed to hook up to under the dash. also what is the easiest way to get to the ebrake wire? i'm in desperate need of help and don't want to have to pay someone to get something as easy as this installed. thanks
1 - 2 of 2 Posts
ok, its not very hard. the wires going to the ignition where you hook in the harness is directly below the steering column tucked up above the plastic that goes across the underside of the dash.
And the Ebrake cable runs from the base of the ebrake lever into the console, just splice into that wire and you should be set.
Hope that helps.
1 - 2 of 2 Posts
