1 - 2 of 2 Posts
J
Guest
I was just wondering if there is a good turbo timer/boost controller combination that I can use with my aftermarket Viper alarm or can I even use an alarm with a turbo timer??? Also wondering if our clutches are adjustable? My petal is a little low and I'm wondering if there is an adjustment for this or is my clutch shot?
Thanks,
Jason
93 Firestorm Red RT/TT
that totally depends on the alarm you have. don't know much about that to elaborate on...but as far as the clutch...yes get underneath the pedal and loosen up the nut that touches the pedal and twist the other end so that the shaft comes out toward you. then feel the clutch it should be higher now...if it feels good just tighten back the nut and you are set! hope this helps!
1 - 2 of 2 Posts
