My front turbo oil feed line from Kinugawa would not fit around the multiple brackets for the turbo downpipes and the ac compressor so I had to remove it. My question now is, is it okay to have my rear turbo using the aftermarket SS Kinugawa oil line and the front turbo using the stock line? I didn't want to go through the trouble of disconnecting the rear aftermarket line if I didn't need to but I started worrying about running two different lines. All of the banjo bolts used looked identical (no restrictors) just wanted someone else's opinion like usual. Thank you in advance.
