1 - 3 of 3 Posts
I just put a new(used) engine in my car that came from a half cut from japan. Today I finally got everything back together and tried to start it. It cranked a few times then very poorly started. I gave it a little gas and it sounded great, except that it smoked a very little. Then I turned it off and put coolant in it. Then I started it again and it was idling at about 2k. Then a few minutes later, i tried to start it again, and it would crank, but it would not start. any ideas?
probably been out of use for too long, probably has condensation on the inside, just warm it up and then break it in again.
Did you change the spark plugs, or just use the ones that came in it from japan? Check for spark.
1 - 3 of 3 Posts
