I’m also in the same process I have everything now I just need the the actual trans but here is the list of parts you’ll need I got from another thread
manual tranny
axles (need to fit the year manual tranny you get)
clutch/pressure plate/throw out bearing
bolts that hold the pressure plate to the flywheel
flywheel
bolts that hold the flywheel to the crank
starter from manual
shifter cables and clips and mouting brackets
shifter assembly w/ shift knob
shifter boot
clutch slave cylinder
clutch master cylinder
clutch pedal/brake pedal assembly
clutch line (1)
clutch tubes (2)
clutch fluid
tranny fluid
