1 - 3 of 3 Posts
So I have read about everyone's torque steer. Well my I recently had my car engine swapped in a shop still had same transmission . Now when I drive it has really bad torque steer when I push on the gas it will pull to the left and when I let off it will pull back to the right . What can I do to fix this. I dont think they adjusted my tie rods and everything just threw it in and said your good to go ?
This isn't normal torque steer, this is a bad alignment issue or something loose - I had a similar problem due to a loose lower control arm bolt.
1 - 3 of 3 Posts
