R
R/T Turbo
·Guest
I took my tranny apart today and the results are the roller bearing with those small rollers caged in the bearing must have broke. From what I see just looking at the gears and syncros they are fine but I found a few small peices of metal at the bottom from the cage of the bearing. I can hear the balls moving around under the gears with no shaft on it, that would be the one in the middle. Its the bearing thats inbetween the back of the case and the bottom of the gear assembly. I think I'm going to have to take the input shaft out to take the middle gear assembly out. Elmo stated that this might be the problem and it is. Now where can I purchase one of these bearings, or can I?
