1 - 8 of 8 Posts
Do any of your springs squeak when going over bumps?
HIGHRISK
Mine don't. But I've only had them for a lil over 2 weeks. How long have you had your springs?
I've had them for about 7 months now. I took the strut assembly apart & put some axle grease between the spring and the rubber strut casings. The squeak went away for about 2 weeks & then it came back. It's only coming from the passenger rear spring:confused:.
The Wizard Of Aaahhhhh's
No squeeks here. Had them in since August.
Chris
I got em too!
Every time I hit a bump I get squeals and my alignment gets knocked out...JC
Discussion Starter #6
Hulk67
Is it coming from the same location as mine? How long have you had yours? This shit gets annoying & embarassing especially when you're pulling into & leaving a night club parking lot or ANYWHERE for that matter:confused:.
I've had mine on for about 2 weeks, I haven't drove it since then..I hope the springs settle while the cars sitting. I think the stock rubber stops are 2 small for the intrax springs.....JC
No squeaks here....
Not sure if this is your problem but....
When you installed the springs did you line up the small hole of the top spring perch or spring seat with the small hole on the lower spring perch.
From what I hear, this is easily overlooked would cause suspension problems.
1 - 8 of 8 Posts
