Stick a big 4 inch bolt in each of the special tool holes. Stick the end of a big open end wrench over one bolt and the other end against the front axle shaft from underneath. When you turn the crank pulley bolt it will push the other bolt against the wrench and volia. I used two big allen wrenches instead of bolts but bolts would have worked better.
Aaron
Aaron
