Dude, I would be cautious. I've heard of some rare and crazy stories like going to 160K without ever changing the timing belt, but I've also heard of them snapping at 70K. It depends on the belt's condition. You may want to check the timing belt yourself for any wear, but I'm not sure how to do that on a TT. Mine has only two bolts on the timing belt cover but I'm an SOHC.
If it looks ok, then only do like 80MPH max and don't be revving too high in the RPMs.
And only use a Mitsu OEM timing belt when you do get it changed, don't skimp out and try to save a few bucks with an aftermarket, 'cause $100 savings now will cost $4000 or more later.
