1 - 5 of 5 Posts
Hey guys!
I hope i didn't screw up something!!!!!?
When I removed my timing belt ,the front bank exhaust cam jumped like 30 degrees clockwise !
I know it wasn't suppose to do that so how am i gnna correct it !
I followed all the instructions checked everything 3 times and still did it to me !
Please help!
Thanx!
Lajos
no speed limits here
It's OK if a cam moves when the belt is removed. Just make sure the 4 cams line up with the marks when putting the new belt in place.
Large Member
yeah, you're cool.. that happens most of the time. Just make sure the marks line up when you go to put the belt back you.. you will probably need help.. someone to line the cam up as you slip the belt on.. it's a PIA to do by yourself.
Gear Head
After you put the belt on use a wrench to turn the crank shaft and listen for pistons hitting valves. Those marks must line up perfectly. And sometimes, as the belt settles during the first few rotations, it can jump timeing. So be sure and rotate the craonk shaft by hand first before starting to much sure you don't bend your valves.
1 - 5 of 5 Posts
