A puller??? lmao Nahhh Here's what you do my man. Outter tie rod:
See the part that the tie rod goes through on the spindle? Ok get a trusty hammer, not a little peg whacker but a descent weight hammer ans wail on the part it goes through....It will pop right out. Don't worry you won't hurt anything doing this.
I do tie rods every day and never EVER had this method fail or cause damage to a vehicle.
Inner tie rod: You need a tool, NOT A PULLER!!!!!!!!!!!!!!!!!!
These are THREADED onto your rack & pinion you need either the proper tool or channel locks and enough room to get these out.
There is also a lock pin in there that must be installed after you put the ineer one back in DO NOT forget this!!! It keeps the tie rod from unscrewing and coming off!!!!!!!!!
