1 - 3 of 3 Posts
Unfortunately, the age of your car points to a defective TPS. You can check the voltage of teh TPS and the Idle switch with a voltmeter at the ECU or ... borrow a datalogger or let the dealer hook up the DRB2 to get the values.
AZ 3/S Tech
any one ever have a problem with the throttle position sensor or related components. i think the dash pot in my car is shot. when i let out the clutch sometimes the RPM's dont drop or they jump a little. i bypassed the vacuum valve that is connected there and it ran the same. any one have any ideas????
later
tim3kgt
Tim Yerkes
cincy
91 vr4
G
Would you guys know if the TPS goes would the car buck? My car has been bucking and the dealership tells me I need to replace the throttle position sensor. Thanks
1 - 3 of 3 Posts
