No and yes.
You'll need calipers, brake pads, and new rotors. The 2nd gen are larger and double sided if I remember correctly. They are also rather large, so I hope you're not running with 15" wheels.
If you just buy an entire rear end off a 3000GT, it should work. They're pretty much the same size and shape. The only problem would be how it is mounted (may be different than your current rear end).
