101 - 120 of 131 Posts
· Administrator
Question for you guys - the 6G72 oil filter stay (MD140084) doesn't appear to line up to the 6G74 block. Am I correct in assuming that nobody runs that stay on their 6G74 swaps? Thanks
Edit: John M. already answered this on his page (http://www.wrenchjockey.com/Webpages/6G74swap.html), it doesn't line right up, but the question remains. Anyone just not run it?
· My car is a money pit
Edit: John M. already answered this on his page (6G74 3.5L Engine Main Swap details!...JOHN MONNIN'S PERSONAL 3000GT/STEALTH FAQ), it doesn't line right up, but the question remains. Anyone just not run it?
I honestly can't remember using mine... I don't think I ever had that bracket to begin with... never bought a completed car, so mine was kind of pieced together.
· Registered
Hello from Europe,
I'm currently looking into getting a new engine / overhaul for my GTO TT.
There are alot (compared to the 3S / GTO) Pajero Engines for low prices here. 60k miles Pajero Engine is around 1400$, a 150k miles F*** up GTO Engine is 2900-3500. (Which probably needs more work than my 150k one).
So the option to take a pajero is pure economic.Not chasing huge Power but around 400 tops. (Drop in engine, and finetune with Chrome +ECU).
Alot of those are 3.5 GDI and some 3.5 DOHC non GDI Pajero Engines.
I did read through nearly all threads, and, 6G74 3.5L to 6G72 3.0L comparison Pictures!...JOHN MONNIN'S PERSONAL 3000GT/STEALTH FAQ this one.
But still there is alot confusing information out there when not having the option to go for a debonair 6g74 one.
For a Pajero the Waterpiping is on the wrong side.
Welding water & Thermostat housing to the correct side isn't an issue.
Fitting / cutting / Welding the 6G74 oilpan and dipstick (With turbo inlets) isn't either for me.
Don't need the PS and Aircon so brackets are not a worry for me.
Oil Filter mount is used from the 6G72 TT block.
But what's confusing is,
Is the Harmonic Balancer pulley used from the 6G72 always even on the Pajero? Just curious if I should go with the Pajero Alternator or not.
The 6g72TT 3T Heads with valves and cams bolt on the 6g74 shortbock?
If I understood correctly the 3A Heads from a non GDI fit, but a GDI one is completly different?
The 6g72TT Exhaust Manifolds bolt into the 3A Heads if you fit them? Or is fittment required?
Cam Gears are used from the 6G74 or 6G72?
Waterpump is from the 6G74?
So timing Belt is 6G74.^
Oilpump is the same as the 6G72 93+?
Concerning 6g74 GDI - different pistons and heads and lower intake? So I would need to Source 6G74 Cam Gears and pistons (e.g. 8: Turbo compression ones from 3sx?) and lower intake.
If I get a DOHC 24V 6g74 non GDI, I can reuse lower intake and 3T heads and running 10: something compression with lower boost?
Thanks for the clarification.
· Registered
Beating this dead horse.
Just have some questions.
How different are the pajero/montero 6g74 heads. TT heads are good to just swap right on? Right?
How do you know what to look for so the motor your looking at has all forged internals? Is there model number or something?
Do they have same correct oil passages required to turbo them and just throw my 6g72 TT billet 15gs right on them? Without issues.
I Know the basics that it has to be transverse mounted and it looks exactly like 6g72 in the photos. (If its not this, its wrong right?)
Lastly, there is no trickery here right? if you get Montero engine. Like how do you tell correct montero/debonair/pajero apart. I don't want to get wrong engine without correct internals.
1994 1995 1996 (listed as)
For AWD 93+ TT car.
Thanks
· Registered
Duplicate. Deleted message.
· Registered
I’ve never run that bracket and had exactly zero oil filter housings fall off the engine.
· Premium Member
DOHC 6G74 heads are the same part number as 2G N/A 3S heads. So yes, turbo heads are a bolt on.
Unless it's been rebuilt previously with an aftermarket Chinese replacement crank, They are all forged.
You'll need to swap on the Turbo oil pump and oil filter adapter.
For AWD 93+ TT car.
Thanks
The Montero/Pajero motor is a longitude mount truck motor... The long block is the only part you'd be able to use. All accessories, oil pan, etc. are wrong. The Debonair or Hyundai Grandeur had the FWD version that is almost a bolt in swap. They are Asian market vehicles that never made it to the states, and you'll need to find one from a JDM engine importer.
· Registered
the Kia 3.5L DOHC from early 2000's is identical, but FWD - you can use various parts off of it such as Lower Intake Manifold, *SOME* timing components, water pump, etc. Crank is forged, 4 Bolt mains, etc etc
when I built my 6G75 with 3/S DOHC Heads, that is where I got the missing parts to make it work - they are EXTREMELY Cheap and very plentiful on ebay, and rockauto.
· 1G Foglights b!tches
Does the 3.5 Kia swap in? The debonair long blocks are getting harder to find.
· Registered
Ok Thanks a ton. Just waiting on Dave & Ray to get back to me.
· Premium Member
It's the closest thing to being usable I've seen in the US market, but still far from a direct swap. As in most 2000-up Mitsu products, it faces the passenger side, making the mounts and accessories different. (2002-2005 Kia Sedona minivan)
· Registered
I’ll probably just stick to a 4Gswap in my son’s car. Don’t want too much hassle with the swap. 3.5 auto and a little boost would be fun little car. He wants to do Race Week so 4Gswap is probably better still for what he wants to do with it.
Carry on.
· Registered
Kia/Hyundai heads look identical, oil pumps are different ( i believe theres a thread on using xg350 oil pumps on here)
Valve covers are different, surge tank is different (i think the lower is the same and can be flipped around on the fwd ones), oil pan upper and lower are different (was checking oil pan on a few since my 74 came with a crushed lower)
Water pumps/housings and intake manifold on the rwd sorento is definitely different, but id assume a fwd 74 one would bolt up, the kia/Hyundai ones would put heater hoses and such facing the wrong way though.
Ive only had one out of the car but didnt get a chance to see if engine mount or accessory mount bosses would be the same. They were very good engines that only had cam sensor or coil pack issues most of the time (besides the sorento balancer bolt backing out which sometimes snapped in the crank making you get a new crank)
Edit: found this
Making a hyundai 6g74 block fit..
· Registered
The Kia 3.5L DOHC and 3.8L 6G75 with 3/S DOHC heads seem to have the same challenges for mounting - overall not that bad
Odd ball oil pump with OFH what becomes Rear of engine to us, causing it to be in way of intermediate shaft - no 3/S oil pump will work from what I could tell.
I just made a block off plate out of 3/8" thick aluminum, and used the two oil ports on the back with the threaded plugs in them to feed my Remote Oil Filter housing via -10AN fittings and Lines. I believe they are BSP/BTSP/BSPTSPSTPS thread but I don't remember exactly what size.
Oil Pan required mild modification to work with 3/S Trans.
*Drain and Dip stick on rear of engine. Dipstick provision is in oilpan itself not block
*No Starter notch, I took some aluminum tubing, cut a section out, sliced the tubing and welded it into the pan - I also had to grind some material away from the girdle - a AWD TT Trans might not need this since the starter sits out further from the engine slightly with the bigger diameter flywheel
*Hack off the brace type thing on the transmission side and use shorter bolts for the pan.
*Much like the JDM 6G74, you'll need to notch the oil pan for the T-Case which means grinding the crap out of the Girdle there too.
a 4 Bolt TT Pan will NOT work, I tried.
I was able to get by using all 72 brackets, and accessories with light to mild modification. Power steering, Alternator, Drivers Motor Mount Bracket boat anchor, etc.
Most of which consisted of Grind away material and or enlarging holes... not the right way but it worked. 3D Scanning the block and heads then having all the parts cut out of aluminum via CNC would be the preferred way to do it given the resources.
the Bosses for the Front and Rear Motor mounts were there, but most were not drilled/threaded the right size or at all.... However making some custom front and rear motor mounts was actually pretty easy coming from someone who is a terrible fabricator... later on in the project I ended up using the IMR Motorplate, which made mounting the engine fairly easy...
The rest is basically the same as the JDM 6G74 Swap guide,
