1 - 20 of 22 Posts
corporate slave
I just got my 3" stainless steel test pipe custom fabricated and installed.....wow...all i gotta say is wow, YES, i did loose power from about 1k to 3k RPM, but the needle shoots from 4k-6k as if I have a turbo or something, its' perfect for runnin around 3k RPM's and waiting for someone to get up next to you, and then WHAM, floor it! you're gone!
plus it has a nice rumble, and RUINER said it sounded good as i passed him ;-)
-brian
ps. he wasn't trying =)
HIGHRISK
Stupid question:
What's a test pipe? Where does it go? BTW, Ruiner's car is slow, I'm sure you really did beat him, lol.
corporate slave
explanation........
go look under your car, find your catalytic convertor, it's about 16" long and is pretty ugly...that is filled with a fine mesh that removes harmful particles from your exhaust
imagine replacing that with a straight 3" piece of tubing...no restrictions, flames, extra gas, carbon monoxide and other carcinogens flying out the back
that's what a test pipe does
you loose a little low end, but gain a lot of high end (on the rpm scale)
you can buy them online, around $30-$80 (ranging from 2.25" to 2.5", stainless steel to chrome)
i got mine for $100 installed, i love it
HIGHRISK
That's alright...Im' getting an entire exhaust sytem. The guy I found to do it puts a Catback in there, but has the exhaust "bypass" the catback ;D Which means I pass inspection without a catback *techinically* lol. Said it runs about $300 - $500. I can get 3 inch piping all the way back too.
corporate slave
Discussion Starter #6
roo1524: custom fabricated at a local muffler shop
esc: $300-$500 for the "bypass" sounds like you're getting robbed...it's pretty damn simple, bolt some piping from your downpipe back to some tips...not hard....
i have the borla exhaust system too, and have had it for about 6 months...love it...but this adds some pep to it
HIGHRISK
I'm not getting just the bypass. I'm getting an entire stainless steel exhaust, from the manifold back to the tips. 3 inch piping with 4 or 5 inch tip, I dunno yet. Sounds like a deal to me though.
corporate slave
Discussion Starter #8
definately!
i must have got good deal
i found a shop that took out my cat and put in a straight pipe for $30, he said that the precats would cost a little more,
Sport Leisure
i'm gonna get a custom downpipe made pretty soon.. probably 2.5".. and i think i'm gonna put on a VR4 exhaust.. should i throw on a test pipe too? i really dont wanna lose any low end power, seeing as i have absolutely none now, especially with my auto tranny..
corporate slave
Discussion Starter #11
it's not enough to cry about, and YES, definately a test pipe, and try to go 3" on the downpipe...2.5 is what you have now i believe, eitherway, 3" is better =)
Badassical Baddage
3" might not really be better on an NA...unless your running a bunch of NOS or planning to turbo it soon.
You'll keep your low-end power with a 2.5" system...
too little backpressure is NOT good, tuned backpressue is ideal, thats where R&D comes from on exhausts...anyone can bend a pipe and weld it on, but to make it flow freely and keep the right amount of backpressure takes some work.
I don't know why anyone would care about losing hp under 3k rpm. When are you ever below that racing? Now, I've got some really shitty tires, and i get wheel spin launching at 2k, but plenty of guys launch their cars at 3k+
.jon
Sport Leisure
.jon
i care.. thats because the only way i can launch is holding down the brake while i rev the gas up to 2K (which is where the rev limiter stops it) and then let go of the brake and floor the gas.. even then all i get is a little squeal of the tires and on, slowly, she goes.. yup, auto trannies suck for racing..
Yeah I agree it is hard to get from 2000RPMs to 3000RPMs with very little back pressure. But if you get a Torque Converter you dont need to worry about Low - End from a stop. ;)
Sport Leisure
ive heard of those before but never really looked into them.. how much are torque converters and how easy are they to install (can i do it myself) ? also what retailers sell them, and what brand/type should i look for?
Well Levelten.com has them and they will install, so does GTPRO and they will install but from what I have heard GTPRO gets there Torque Converters from Protorque.com. So you may want to look into them. They are about $300 - $400 and are a sound mod for an N/A if your tranny is pretty new. I'm guessing around up to 50,000 miles it should seem like a good mod, until your tranny goes than it is your choice whether to keep the ATX or go for the 5-Speed. Any car with more than about their 60k tuneup can be considered a waste of money if you are going to swap to a 5-speed but the good part is that you could always sell it on the board for a fairly good price. HEHE.
You cant really do it yourself unless you are really experienced with the car. I think you need to seperate the tranny from the engine to get to the damn stock Torque Converter, so it is a hugh 3 - 5 hour job depending on if you know what you are doing and how good you are with cars. Installation is a bitch so a mechanic will charge you alot but it is worth it. HEHE
Also if you get a Torque Converter you will have to get a Shift Kit and Clutch End along with it. Not to mention a tranny cooler. Talk to Mikes95RT . He has a the kit and runs flat 15's on his G - Tech with his ATX!!!!!! HEHE:D :D
Hope I could help and contact Mikes95RT. ;)
i've been debating getting a test pipe for my N/A, i think after reading all of this i will get one. i dont like the fact of losing low-end, but i def. need some high end, the high end on my car feels kind of weak. anyway, some with N/A's think that they didnt lose any power, that it was all gains. my friend with a integra vtec put a test pipe on there, and he loves it. the test pipe replaces the cat thats just right after the flex pipe, right??
corporate slave
Discussion Starter #19
correct, it's not going to loose a whole lot of low end...but i do see what the claims are now, when everyone said i'd loose low end, if you pay attention, you will notice it, but otherwise it's hardly noticeable, i like the sudden pull around 4k, feels like i have a 1g turbo =D
W3Si member #010
From what i understand, you shouldnt lose more than a tiny bit of low-end due to the backpressure being kept by the downpipe and manafolds. And that from about 3grand and up the power is really felt in an n/a anyways. We dont get peak tq til 4500 and peak hp at 6k. I would love to lose a tiny bit of low end and gain alot of high end. That will release some traction problems maybe and really allow a killing from a roll. ;) I will be getting mine real soon. I will post before and after feelings of it. Godd luck.
1 - 20 of 22 Posts
