1 - 7 of 7 Posts
I put the $30 test pipe on today. It was easy enough to torch the four old nuts off of the cat and bolt the new pipe in. I didn't notice any change in sound. I didnt lose any low end power and in fact it feels stronger all around especially before 3000 rpms. I can definitely feel a small difference. The throttle response seems better too. For $30 I feel it is worth it.
Aaron
Please explain
I've heard the term "test pipe" and it's somehow related to failing emissions :) Can you please explain what it actually is ? Does it somehow stop your active exhaust from workin ?
Lost Soul
It replaces the CAT. The cat is what lets you pass emissions. By filtering the air so to speak. By getting a downpipe you are basically allowing for air to flow through, which means more power, generally.
They use a mirror or get down on all 4's :) to check to see if you have a cat, if you don't you fail.
Test pipe bolts on, easy take on easy take off.
-Jeff
FreakAccident!
96 models have pre-cats and a main cat which is what you replaced.
I have a 95 and my brother has a 96, this is how I know.
My 95 model with a test pipe sounds BEAUTIFUL, very Italian if you will.
How do you like the smell? My car smells just like a 69 Chevy pickup..frakng stinks but it is well worth it...the best $30 I ever spent.
Discussion Starter · #7 ·
I cant smell anything. It sounds exactly the same too. The only thing I noticed was the major increase in low end power. I can smoke the tires all the way through first and if my clutch wasnt trashed I am sure it would smoke through second too. Maybe I should gut the precats and see if the sound changes.
Aaron
1 - 7 of 7 Posts
