1 - 4 of 4 Posts
One fix at a time
Brand new 2.5" all the way through aluminum turbo intakes. I've had Dejon and IPS intakes but wanted something a little different that didn't neck down before the turbo to 2.25" pipe so I built some. These fit AEM dryflow 21-2011DK filters but any filter with a 5.5" base diameter or less will fit side by side. This sale is for the front and rear aluminum intake pipes only. You'll need to buy couplers, clamps, and filters of your choosing. The piping was polished from the manufacturer but does have some scuffs and scratches from fabbing so you'll need to either finish wetsanding and polishing, powdercoat, or paint them. Price is $200 shipped in the lower 48.
Just so there's no confusion, this is for running speed density with a MAFT Pro or a standalone engine management such as an AEM EMS, or you can run it blow-thru with a GM MAF sensor. I also can offer a LS3 slot style maf setup welded into an intercooler pipe and/or y-pipe but you likely will need Chrome in order to tweak the maf size and scaling tables. TurboBob confirmed it will work with the MAFT. I attached a picture for an example. Let me know if you have any questions.
IMG_2320.JPG IMG_2379.JPG 72472775_10101249996579219_6611356253811638272_o.jpg
One fix at a time
Discussion Starter #4
Just want to say I am running these exact intakes on my car. I love the quality.
Thanks. I should be coming out with some TD05 intakes shortly as well as hopefully some TD05 manifolds and an aftermarket front TD04 manifold if all goes well.
1 - 4 of 4 Posts
