1 - 3 of 3 Posts
1994 3000GT VR4
Mix of TD04 and TD04H parts. I want to say the prev owner had "upgraded" to "15g" turbos, which I promptly removed and installed MHI 9b units (or so I thought).. one was actually a 13g but that was just as well. Anything but unknown china stuff.
So, there are a couple of TD04H comp housings, TD04 comp housings, a couple of TD04 exhaust housings, and an O2 housing with O2 sensor and pigtail.
One turbo is assembled, and it may be a 15g. Has a little shaft play but not contacting housing. Comp wheel is pitted for whatever reason. I can measure the inducer if someone really wants. Would I recommend running this? Hell no.
If a price is needed, let's go for whatever shipping costs or $25. Hopefully someone can make use of some of this or at least some of it will be trashed.
Think I had the other comp wheel and tossed it. That one had contacted the comp housing. Needless to say, I didn't run these turbos for one second when I saw what was up.
3SNY - HondaTurtleFTW
Is that a front or a rear pre-cat housing?
Sent from my HD1907 using Tapatalk
1 - 3 of 3 Posts
