1 - 9 of 9 Posts
MI SCUZI! MI SCUZI!
Keaka26: last nite, coming out of dennys, the clutch pedal got super light...like, lighter than stock, and i had to jam the pedal to the floor to shift...
Keaka26: if i pumped the pedal, sometimes it would stiffen up to almost normal i think
My friend just sent me that. Any ideas? Sounds like Clutch Slave Cylinder to me but I could be wrong.
Lost Soul
Add fluid....for now then replace the slave cylinder. Mine did that then I replaced Slave then a month later I was replacing a Clutch.
-Jeff
same thing happeneed to me, i was almost completely out of fluid, then i had to get the slave cylinder replaced
Same thing happened to me i thought my clutch was blown, then a needed a new slave cyl.
But just needed to bleed the system then re-fill. Air was in the lines...:D
Lost Soul
I bled mine it wasn't hard but it didn't fix the problem either.
-Jeff
1 - 9 of 9 Posts
