1 - 5 of 5 Posts
· Registered
1997 VR4, 1999 SL
Hi guys, i have a 97 VR4 with a working stock infinity radio, amp and 10 disk changer, im curious to know if the first gen radio with the digital equalizer screen will work with the gen two system without modification, i kn9w its ment for a 6 disk changer, i just want to know if it will work with the infinity amp and stuff. I'd only want it because it looks cool, thanks
· Super Moderator
A 93 would be plug and play but won’t use the amp. Also the dash speakers would be out. As you know the 10 disc cd changer is not compatible.
· Registered
1997 VR4, 1999 SL
Discussion Starter · #4 ·
Soley for the opinion that the older digital ones screen more matches the interior aesthetic of the car/ matches the chromatic display for the a/c controls. Objectively it is a worse unit, but im not entirely concerned about audio quality in a 3000gt, i have many other audio devices that fit that need, however based on Daves response stating that the amp and front channels wont even work i no longer want the older unit.
· Super Moderator
The 93-99 cars without infinity systems had the door and dash speakers jumperd in whe wiring above the radio plug where as the infinity system fed the dash speakers separately thru the amp.
1 - 5 of 5 Posts
