AHA!
Found some good shit...
LH Inlet Camshaft MD150391
(MD175577)
MD175577
MD192011 1
1
1 9004.1-9201.3
9202.1-9205.3
9206.1-end Cam height (std):
up to 9205.3: 35.49
from 9206.1: 34.91
Journal diam.: 25.96
Lift (gross):
up to 9205.3: 0.375 inch
from 9206.1: 0.352 inch
Valve timing:
opens: 16º BTDC
closes: 55º ABDC
Duration: 251º (gross)
Duration: 208º @ 0.050"
Lobe separation angle:
108º cam
Overlap:
33º crank, 16.5º cam
Overall retardation: 1.5º
LH Exhaust Camshaft MD159598
MD192019 1
1 9004.1-9205.3
up to 9205.3: 35.20
from 9206.1: 34.91
Lift (gross):
up to 9205.3: 0.364 inch
Valve timing:
opens: 50º BBDC
closes: 17º ATDC
Duration: 247º (gross)
Duration: 206º @ 0.050"
108º cam
Overlap:
But, then again, that's for the DOHC TT....
