1 - 3 of 3 Posts
I've tried searching and didn't find an answer. After having the ECU replaced in my 1991 Dodge Stealth Turbo I noticed the stock boost gauge has stopped working. Everything else seems to be fine and the turbos do spool up.
So has anyone had the same problem? Is it a faulty ECU or was a wired not connected properly.
Thank for the help.
If it was a direct result of the ECU swap, that's where I'd look. Either a defective ECU or the wrong one.
my stock boost gauge started going wonky before I ogt my new ECU... New (Chrome ECU), and functioning normally again. So based off of only my own car's experience, I would guess ECU...
1 - 3 of 3 Posts
