1 - 12 of 12 Posts
Hello, I was wondering if you guys could give me a step by step on pulling a mtx from a 1997 base model and putting it into a 1997 base model with atx. I've been all through your threads and most are about TT and I have no interest in a TT at this time. I'm pretty good mechanically I just need to know where to start and what to take out. also what's this stuff I see about getting the cruise control to work? if the both have cruise control shouldn't they just plug right into each other and why do I have to bypass certain plugs can't I just put the mtx wiring harness into the atx car? so I have every piece I need I have 2 cars both complete for the most part. one has an amazing body no rust and sweet just wont go forward with atx. and I have one that the body is complete shit and doesn't run due to an incompetent wannabe mechanic buying before I did and taking stuff apart with no idea what to do and has an mtx. I want to pull the mtx and everything I need to do the swap and I mean full swap so everything works and no cutting wires or mickey rigging. I can gut whatever I have to gut I can pull whatever I need to pull. I've tried looking into the black book parts catalog and the transmission isn't even there. Thank you.
Discussion Starter #2
It's ok if I can't get instructions on how to pull everything just need a complete list of what needs to be pulled and I can do the rest and maybe what order to make things easiest.
i found on on another post for removing the ATX it's for the FWD that is on both tires, don't think my manual has them both hooked up but will check, now need to find MTX removal guide. if someone could point me in the right direction and let me know if it's worth replacing the wiring from atx to mtx thanks.
Pulling the manual trans is quite straight forward. Drain it, remove the CV axles, pull the battery, battery tray and washer reservoir, intake up to the throttle body, shift cables, speed sensor, backup (reverse) switch, slave cylinder, transmission mount, starter and frame member. Support the trans from above with an engine crane or from below with a transmission jack, remove the bell housing bolts and slip it away from the engine then out the bottom.
Hope I didn't forget to list anything. Basically if it's attached to the trans you make it be not attached then separate it from the engine.
Can't help you with the swap any more than that as I've only dealt with the MTX. If you want/need more info on pulling the MTX just search for how to replace the clutch. The fwd trans should be the same process as an awd trans just without the transfer case.
Have you read up on the clutch pedal box swap?
Discussion Starter #5
I have read up on the pedal, Thank You. I was thinking about fixing up the automatic. but not sure it's fixable. just got the car with the auto today.
I did this swap 15 years ago. Basically pull the trans, torque converter, flexplate, etc everything related to the trans.
1)If you have mtx wiring swap it in or you have to do some wiring with the park neutral switch. Cruise won't work if you just jumper it to think its in park or neutral all the time.
2)The starters are different.
3)The axles are a little different.
4)Get a 1 1/8" (iirc) hole saw to drill the clutch master cylinder hole when you install the mtx pedal box. You may need a very small drill or right angle adapter to get up in there. Drill it from under the dash outwards. Just get one of the braided clutch lines like stm sells.
5)Its kinda hard to swap the shifter base in the car with the console in, but it can be done if you are a little rough on things. I think I had to cut one little piece of plastic to do it.
6)Flywheel bolts are longer on the mtx so grab them.
That's about all I can remember at the moment, but if you get some specific questions let me know.
I think supercar engineering has a step by step. I think thats what I used when I did mine 2 years ago. I quick google search should help.
Discussion Starter #8
Is it possible to remove the trans without removing the CV shafts first? I 've been trying to get the nuts off the shafts on the brake rotor and they won't budge. I snapped my 17" breaker bar with a steel pipe extension trying to remove them. I've heated them, I've sprayed them, I've tried tapping them, I'm at the point of cutting them off with a cutting disk and angle grinder.
Discussion Starter #9
Also is the number on the trans supposed to match the vin of the car if it's the original trans? both trans the MTX and ATX have different numbers on them than the cars they are coming out of.
Discussion Starter #10
Just a question. i know the CV axles aren't5 supposed to be swappable but I pulled them both and put them side by side and butted the teeth together and I can't see a difference in teeth or size. can i def not put a ATX CV axle from a 1997 base into an MTX 1997 base trans?
Discussion Starter #11
Ok I don't know if anyone is reading this but I need help. I need to order the braided clutch lines. I saw a link in another post for the lines but now I can't find it anywhere and I've been looking for days. Please someone help.
Discussion Starter #12
Ok I need help please someone respond. In pulled the mtx and one of the spacers came out on trans, I pulled the atx and both spacers are on block. How do I remove one of the spacers and from where to get the mtx on the engine?????
1 - 12 of 12 Posts
