I am currently in the process of buying a tt stealth but i prefer the way the vr4 looks when it comes to the front and back bumpers, was wondering if I can just buy a vr4 front and back numbers and just slap them on the stealth like a bolt on , or is it not that easy?
Rear bumper will require drilling out the spot welds of the bumper support bracket, and re-welding it lower, into the correct position for the 3000gt rear bumper. You'll need the wiring harness pig tails for the tail lights/reverse lights as well.
Sail panels unbolt, but you'll need to cut out the quarter windows and re-install/glue in the 3000gt quarter windows.
You'll also bees to swap the interior rear water window trim panels.
Front bumper headlight and turns are relatively straight forward, as are the sideskirts/door caps.
