I just wrapped up a complete rebuild on a 95 vr4 and having idle issues. Bought it from the second owner who let it sit since 2008. I did not attempt to start it knowing fluids, fuel, and timing belt would present possible damage to the motor. After I hauled it home I pulled the motor, replaced everything including bearings, rings, hone, and a complete valve job along with proper machining work on block and heads. I dumped the 5 or so gallons of fuel that sat in the tank, thoroughly cleaned the tank and hanger assembly, replaced pump, strainer, and filter. I checked and repaired any vacuum leaks present, replaced all hoses for intercooler and cooling system. The timing belt is Gates, tensioner is Gates, and verified several times that it was in time before buttoning it up. The intake and exhaust camshafts are in their respective location along with the sprockets. No after market mods and all stock aside from the radiator. I've been lurking in the forums for a while and tested/ replaced the following:
TPS did not give 400mv-1000mv reading per procedure, replaced with new unit and clocked per procedure.
IAC valve was stuck extended and did not meet the 40om on across the board with a few 0 readings-Replaced with new unit.
MAF harness side read voltage across its pins as per other forums specs and did not make a difference unplugged while cranking.
Cam and crank sensor harness side tested good, rpm is displayed accurately, fuel and spark is present and is taken away with both unplugged. both sensors display reasonable 0-5v reading while turning motor over by hand.
Checked fuses and relays, fuel pump relay clicks when starting-not sure when it stalls, ECI fuse is good.
Coolant sensor reads a reasonable temp.
Starter fluid didn't help
I've put ATF into the cylinders with no major difference to idle.
Spark tested good before and after it stalls
Tried two different fuel pumps, on a Delphi now, and no start with it hotwired. With hotwired it will catch very low(300 or so) rpm but not enough to idle
It will start and stall immediately, and won't start unless I unplug the cam+crank sensor, turn it over for 10 seconds, then plug in the sensors before starting again.
Fuel pump hotwire test connector gave constant fuel supply but did not change idle. Fuel pressure gauge order waiting on arrival
Verified crank-cam timing and intake/exhaust camshaft location on each head again
Pulled ecm, sonic cleaned it, replaced three radial capacitors with no change to condition.
No CEL
Found a used ecu that was reported to be working and it did not change anything.
Unplugged ECS without change
Verified no major vacuum leaks with smoke tester on four different occasions.
Spark and injector pulse is present after stalling
Pulled egr and verified valve moves with appropriate vacuum and its incredibly clean as is.
Swapped injectors for oem known working- no change
Hotwired fuel pump per stealth316 instructions.
Without fuel hotwire:
No CEL
