It is your air bag light "supplemental restraint system". There could be a problem with your air bag system or it could just be a result of a low battery. Try turning you ignition switch on and off 10 times. Don't turn it far enough to kick in the starter, just go until your warning lights come on, then turn it off again. Repeat that cycle 10 times. As strange as it sounds, that does work in the '92 cars if your battery has been low for any length of time.
It's a cheap fix if it works for you.
Les
3SI #221
