1 - 9 of 9 Posts
A few days something started squeking a bit under the hood. Quiet, but audible. Now it's squeking pretty damn loud. It only does it at very low RPM, independent of vehicle speed, louder with the A/C on. Also seems to do it more after a lot of driving. I'm guessing it's the alternator? How do I fix it?
Thanks!
perpetual college student
tighten the belt
you have to remove the driver's side front wheel, then the 2 plastic pieces (along with accompanying bolts and screws) that are around the tires, then you can see the pulley to tighten
3000gtvr4racer said:
I have this exact same probleme and am trying to fig it out also.
have you tightened the belt? You may need to replace it.
i had the 60k mile tune up a while ago liek 2 months then it started doin it about a month after i got it replaced.
probably just needs tightened, takes 20min maybe
1 - 9 of 9 Posts
