Ok I gotta question for everyone.
Has anyone ever had there car make a squealing sound that seems like it is coming from the front drivers side of the car at about 3500 - 3700 RPM kinda sounds like it would be a loose belt but it only does it for about a second. My car started doing this right before the clutch went out. Since then I have had a new clutch, hub assembly, all new belts, water pump, driver side engine mount, and it is still making that noise I thought I would have fixed it when i replaced the Timing belt cause there was a lot of slack around the water pump and could move it with my hand, the belt wasnt snug against the wheel.
So any suggestions would help alot I'm gonna go insane if I dont figure out what is causing this noise.
If you help me THANK YOU in advance
