I posted this on the general forum too, but im posting here to try and get some more help (im replicating the other post). Tonight I was listening for noises from my engine and I had a light and I noticed speckles of a wet green fluid(coolant). THis was on my top IC pipe right where it goes over the top rear timing belt cover, then I look on the side of the top rear timing belt cover and there are speckles of green fluid all over that too. I dont see any coolant on the ground or anything. I pulled the front top timing belt cover and there isn't any fluid on it or the timing belt. Once the car cools down Im going to pull the IC pop and take off the rear top timing belt cover (that fluid is on) and check that side of the belt. If there is any otehr place you guys think this may be coming from besides the waterpump please post your advice/opionion/ideas here!
-Thanks!
-Thanks!
