My Map sensor has a different connector than my speedo, They are definitely not switched, I dropped it off at a friends place, He owns a mitsubishi repair shop.
Thats a huge clue right there, Your ECS is part of your speedometer circuit. Pull the ECS computer and check for leaking caps. If they are leaking thats most likely the issue.I'm usually pretty good at figuring stuff out, but this one has be stumped
I replaced my speed sensor thinking that was the problem but it wasn't also replaced the gauge cluster along with the little gear inside the tranny the damn thing still doesnt work. Neither does the cruise control and the ecs is blinking now these things just stopped working at the same
Time
Any help will be greatly appreciated
Agreed it needs to be checked, but it could just as easily be the ECS computer setting a code 24 for no VSS input.Thats a huge clue right there, Your ECS is part of your speedometer circuit. Pull the ECS computer and check for leaking caps. If they are leaking thats most likely the issue.
I'm getting about fed up with driving with a GPS system. I need my Speedo back!!!! it didn't start until after I put in the AEM
