Hey guys I got this 93 vr4 that came with the chrome stock rims and I need the special tool for the special lugnut. I bought a $60 set off of 3sx but the tool isn't fitting my lugs properly. I'm wondering if someone out there has one that I could borrow, I only need to use it just the one time! I'll install my new set off 3sx if I can successfully remove the original one and I could send you your tool back along with the lugs if you waant. If anyone can help me out I would really appreciate it just send me a pm or comment here. Thanks!
Using a locking lug nut removal tool to get the old ones off .... and or a socket size large enough to go around the old locking lug nut this is another trick to get them off as well ... being very care with a extension to pound on the removal tool of your choice but you should be able to rent one of these tool sets at a near by tool / parts store
Use a extension on the tool to pound it on ..... so in case you slip up with the hammer you don't smack the face of the wheels
Use breaker bar or impact wrench to take them off with
You should not have to jack the car up to remove old ones leave in gear / set park brake
Torque your lug nuts ( min ) 89 foot pounds ( max ) 100 foot pounds
DO NOT "UH GA DA GA" !!! Them down with impact .... warp your brake rotors.... causing pulsation while braking / damages lug nut threads and studs as well
Torque Wrench please
