1 - 4 of 4 Posts
Ok guys, another question
I am also changing my spark plugs from Denso Iridium IK 24 to IK 27. What gap do you suggest? Is it possible to change gap on Iridium spark plugs? I will also hotwire my coils. Wil run alcohol/watter injection also on dr750.
If running lots of boost, you want to close your gap more. my built 300zx i was at .018 on my evo I am .022 on a 3kgt .025 should be perfect imo as long as you are betweek .022 to .030 you should be fine
Try .030" up to 20lbs boost, .028" to 22 lbs and .025" to 24lbs of boost. You may be able to get away with a wider gap with the hot wired coils, but I don't think you will lose anything
with those gaps. And yes, you can gap the iridiums, but be careful not to damage the electrode. Personally, I would run coppers and just swap them out every 6k miles.
Wayne
1 - 4 of 4 Posts
