1 - 19 of 19 Posts
1993 vr4 pearl white 127000 miles mods: Vaccum delete, MBC,k&n filter,3in downpipe, ninja oil pressu
I have a 1997 sohc 3000gt that im parting out, car has 117000 miles on it. Motor has a blown headgasket(doesnt run, has milky oil, but definitely isnt seized up) trans is good as far as im aware. All body panels are gone, but i have the motor and auto trans plus all suspension and driveline parts. Has tan leather interior and automatic sunroof(dont think it works). I also have for sale off a 93 vr4 a hood in very good condition, 2 side skirts one alittle cracked one in great condition, a front bumper, pop up headlights, 1g front fog lights, 1g white passenger fender in decent condition(some rust on part that sits under side skirt. The hood I think would have to be local pick up only as itd be to expensive to ship. Im near Akron, Ohio. Feel free to ask any questions and make offers. Update Stock stereo, cd changer and bracket, rear strut caps, both 2g doors, and the 1 fender are all sold.
288469
288470
288472
288473
288474
288475
288476
288471
Senior **i.e. OLD** Member
Not EXACTLY sure if the front end under body plastics are the same, but I need the drivers side piece that attaches to the wheel well plastic and makes up about 25% of the underbody.
There are two outside pieces and one center piece.
Only need the piece described above...
This is for my 92 Stealth TT...
Bob.
Ill take some pictures and put them up
Thank you sir!
Bob. :)
Discussion Starter #5
Thank you sir!
Bob. :)
I did look and I have that plastic piece in good condition. I realized though that my vr4 doesnt have one, so Im going to try to locate mine before I let this one go.
Discussion Starter #6
bump
1991 Dodge Stealth Base SOHC ATX
I'm wondering if the transmission computer will work for my 1991 base Stealth, do you know the part number?
Thanks!
Discussion Starter #8
Ill grab the part number when I get off work today. Im not sure about the compatiability with the 91.
I could also use some other parts: the passenger side dash vent, and the 6-pin connector for the IAC with a couple inches of wire.
Edit: The IAC itself too if it's still good.
93 NA ATX 3000gt DOHC
Thanks!
Yours is 3 plug connector configuration ’93 and up is 2 plug connector configuration, so keep that in mind when searching for TCU/TCM.
3SNY - HondaTurtleFTW
1g ac compressor shipped to 32908?
Sent from my HD1907 using Tapatalk
Discussion Starter #13
Make an offer IAC is working as far as i know ill try to check it on my vr4
Discussion Starter #14
Sadly the 1g compressor is staying. I was hoping to swap for the r134 compressor in the 97 but its not possible so im stuck dealing with r12.
I have a 1997 sohc 3000gt that im parting out, car has 117000 miles on it. Motor has a blown headgasket(doesnt run, has milky oil, but definitely isnt seized up) trans is good as far as im aware. All body panels are gone, but i have the motor and auto trans plus all suspension and driveline parts. Has tan leather interior and automatic sunroof(dont think it works). I also have for sale off a 93 vr4 a hood in very good condition, 2 side skirts one alittle cracked one in great condition, a front bumper, pop up headlights, 1g front fog lights, 1g white passenger fender in decent condition(some rust on part that sits under side skirt. The hood I think would have to be local pick up only as itd be to expensive to ship. Im near Akron, Ohio. Feel free to ask any questions and make offers. Update Stock stereo, cd changer and bracket, rear strut caps, both 2g doors, and the 1 fender are all sold. View attachment 288469 View attachment 288470 View attachment 288472 View attachment 288473 View attachment 288474 View attachment 288475 View attachment 288476 View attachment 288471
I'd love to buy all of the plastic cover bits from the drivers wheel well with fasteners. My car has none on the drivers side. Also a battery tray with the hold down and washer reservoir (not the two brackets that hold the tray up, I have those). Also the fuel pump cover from under the spare tire on the right hand side. Defroster vents front the dash would be good too.
Let me know what of those thing you have and how much you'd be looking at for them.
As far as shipping. I'm in Bakersfield CA 93311.
1 - 19 of 19 Posts
