1 - 8 of 8 Posts
Hi All,
Got a '93 SOHC that won't start. Syptoms:
  • Issue was intermittent at first and only would not start when the engine was warm, but now won't start all.
  • Engine turns over but won't run.
  • Once started, ran like normal (when it did start).
  • Fulled charged new battery will completely discharge when connected at rate of 1 Ah an hour- no lights or anything else on
  • Can hear faint clicking sound from behind or under intake plenum - can't isolate
  • Tachometer doesn't move at all when trying to crank engine, but engine IS turning
Here's the troubleshooting I've done thus far:
  • New Battery - old one died after repeated discharges
  • 6 Month Old alternator
  • New Ignition Coil
  • New ICM aka Ignition Transistor
  • New distributor cap & rotor
  • Tested MFI Relay per service manual & tested good
  • Connected inductive timing light to wire from coil to distributor - fires once ever 5 seconds or so when cranking engine
  • Pulled ECM & visual inspection shows no major defects - have new caps & planning to replace anyway
  • Connected test light to diagnostic connector & no codes are flashing - just steady unbroken "no errors" blink
Based on the service manual it seems like the only thing that would cause these symptoms that I haven't already checked is the crank/cam sensor. But I can't figure out how to test it.
Please bear in mind I'm a decent troubleshooter, but not too bright with cars so don't assume that I did simple stuff I should have; if I didn't list it above, I probably didn't do it.
Any help is appreciated.
you need a multi meeter with waveform to test the cam/crank sensors. I don't believe they are your problem anyway. Sounds like an electrical problem. If your battery is discharging I would start there. Unhook the negative battery terminal. Hook a test light from the cable to the battery post. If you have a draw the light will come on. With that connected start pulling fuses one at a time. When the light goes out you found the system that has a draw.
Did anybody ever figure anything out? I have a 97 base 3000gt sohc and it won't start now either... Fuel system is good.. is there a way to test for distributor or can you guys tell me where the crank sensor is?
93 NA ATX 3000gt DOHC
One post is enought see your other post for answer.
Same problem here help plz the car was just working fine then I change the antenna to put it back starts fine then it dies on idle now it doesn't even start fuel everything good
1 - 8 of 8 Posts
