1 - 4 of 4 Posts
So still no spark. As of right now, it has a new ptu, the coils have 12v, the wiring for the ptu is correct. Old plugs and wires that came with the motor. The ecu pulls 1 trigger count error, no trigger errors and syc is full. Has fuel on all 6 cylinders. Just no damn spark. Any ideas would be useful. Anything... running(sitting) on haltec elite 550
1993 3000GT VR4
double check all your grounds (especially for the PTU and ECU). IIRC this is on a 91 or 92 with the single CAS? How is that wired up?
1993 3000GT VR4
the CAS should be wired up with 2 signal wires to the ECU, one for the crank position (trigger) and one for the cam position (home), along with 12V power and ground. Ground should be pin 4 (Black), power should be pin 3 (Red), crank position should be pin 2 (Blue-white), and cam position should be pin 1 (Blue-red).
1 - 4 of 4 Posts
