1 - 3 of 3 Posts
I just got iceman's corners in, they look great and it's not just the love of my own car. I'm a 1st gen, and with superwhite fogs and the headlight conversion on the way, I wanted to keep the corners in the same scheme. I ordered them in superwhite too online somewhere, but an experience with a friend makes me think the wattage won't be enough to make it look any different. Therefore I was wondering if there is anywhere easily accessibly where I could tap into the lights or even just a power source that comes on with the car, jump a thin diode isolated wire from that to the corners.
On another topic, mixing dot 3 and 4 brake fluids, or half synthetic valvoline with fully synthetic castrol, should either of those be a problem?
Thanks for everything,
Nila
More Than Meets the Eye
You won't make bulbs any brighter with a different power source. You'd need brighter bulbs (aka: higher wattage).
But, if you put in one superwhite corner bulb and one regular corner bulb into your clear corners, you'd see which side had the regular bulb.
1 - 3 of 3 Posts
