1 - 3 of 3 Posts
Distinctly_Dave
Anyone know the part numbers for the tapered roller bearings (small bearings) for the transfer case? Or -- anyone have a good used cheap transfer case they are willing to sell or the internals with bearings that match the small bearing dimensions noted on 3Sx.
I might have what you need .....i just acquired some parts and i can check dimensions. Text me at 313-378-0034 for a reminder.
Thanks,
Patrick
I used the list from ninja performance (25 splines, 5 speed, needed the cover side big bearing):
Transfer Case Bearings
Input Spool Bearings - Side Cover End
5 spd Transfer Case Side Cover Small Bearing (no site bolt in side cover) - 32009
5 spd Transfer Case Side Cover Big Bearing (site bolt in side cover) - 32010
6 spd Transfer Case Side Cover - 32010
Input Spool Bearings - Input End
5 spd 18 Spline - 32007
5 spd 25 Spline Big Bearing Transfer Case Spool (site bolt in side cover) - LM710749
6 spd 25 Spline Transfer Case Spool - LM710749
5 Spd Transfer Case Pinion Shaft Bearings
Small Bearing on Splined Output End - 32007
Large Bearing on Pinion Gear End - 32208
6 Spd Transfer Case Pinion Shaft Bearings
Large Bearing on Pinion Gear End - 32209
Seems like your bearing is: LM710749, I think it's a timken but can't find it online, the 32010 was really easy to find for me.
1 - 3 of 3 Posts
