1 - 4 of 4 Posts
Boost Junkie
I have a '94 base 3000GT, does it have the same engine as an SL model or is there a differance, thanks in advance guys.
M
Guest
Yes, it has the same DOHC as the SL. In 1997 on up (the ones with the arch rear wing), the base scaled down to a SOHC engine producing somewhere around 160 hp compared to our DOHC 220.
Boost Junkie
thanks alot Mr.Grimm
S
Guest
Mr. Grimm is right, '91 -'96 the SL and Base share the same engine 222hp. '97-'99 the base did go to the 160hp SOHC, while the SL has the DOHC w/ 218hp. A noticable difference when driving the 160 SOHC engine!!! Much slower, but still looks great!
1 - 4 of 4 Posts
