1 - 2 of 2 Posts
I am doing a water pump change out and replacing all timing parts as recommended the question I have is I made sure the motor was at cylinder 1 tdc with all timing marks lined up I am using cam gear locks to hold them an place I reading the manual it says you turn the crank gear back one tooth when putting back on the timing belt do I do this with the locks in
Member #538
Yes, the slack in the belt will come from the back of the engine and everything should line up when tensioned. Just turn the motor over a couple of rotations to check alignment.
1 - 2 of 2 Posts
