Resurrecting an old thread to update it with new information and a script with different hotkeys.
So AEMTuner 3.2 to turn on Follow ECU - On the Fuel Table there is an down pointing arrow in the top right hand corner that will open the display settings but on this bar is the Follow ECU option. It took me a long time to find this information for some reason.
Next the Windows 10 and AutoHotKey and AEMTuner:
To run AEMTuner I have to run as Administrator, thus AHK can't pass keystrokes because it doesn't have authority SO run AHK as Administrator also and it can then pass the keystrokes.
Finally because I had to diagnose why it wasn't working I played with the hot keys and here is what I'm using:
set the QuickTune to F12
Start the script to Shift+F12
Subtract Time Shift+F10
Add Time Shift+F11
Pause/Unpause Script Spacebar.
Car OFF
I run the script first (Right Click on Script File - Run as Administrator).
Switch to AEMTuner, Fuel Map Tab, Make sure Follow ECU is on.
Press Shift+F12 to launch the key pressing.
Press Space Bar to pause the key pressing.
Start the car let it warm up
Start Driving
1) Press Space Bar when you want to start Quick Tuning
2) Press Space Bar to pause Quick Tuning
Repete 1 & 2 as needed.
NOTE as you can see I didn't change the script very much.
#NoEnv
SendMode Input
SetWorkingDir %A_ScriptDir%
Time:=1000
Space:
ause
+F10::Time-=500
+F11::Time+=500
+F12::
Loop
Sleep, Time
Send {F12}
TrayTip,Autotune Update Rate,%Time% mSec,1,1
if(Time <= 500)
Time:=500
if(Time >= 3000)
Time:=3000
Enjoy!
