No, that's how I also took it.
They do 'sync' between them... assuming its been setup correctly. Normally the torque settings for each box are the same and they can be adjusted to even the load/resistance between the axles.having said that, I'm not sure HOW a hub dyno can do this....hub dyno's have any way of linking the hub rotation between the boxes do they? I assume if this really was a serious issue there would be a whole lot less hub dyno's around, look at all the cars around with VCU's.
Still this. Plumber comes tomorrow then we need to paint.Ensuite then car homes. Maybe.....
