1 - 4 of 4 Posts
.5 Man .5 Dinosaur !!!!!!
Can someone please help me and tell me what should the rpm's be at idle?
Mine are @ 1200.
It just started doing this today after I got a Gel cell battery.
Can this be the cause?
Any help will be apreatiated.
Lost Soul
On my 93 SL it idles at 650-700. When I first start it idles around 1200. The it drops down. Try letting it run a for a bit incase something needs to reset.
-Jeff
og
like darktrail said, rpm at idle should settle to ~700 after starting up, at start it will idle ~1200. things that could change this are adjusting your idle control screw or lightening the mass on your crankshaft (i.e. udp or flywheel). hope this helps, safe travels.
- mike
In cold weather my car revs up to 2000 and then it works its way down to 1000, then after driving for a short while it gets down to 500 (without AC on, with AC on its more like 700-900)
1 - 4 of 4 Posts
