1 - 6 of 6 Posts
G
My mast is broken on my 93 SL. So as I went in to pull the motor and old whip out i found a network like RJ45 cable in the the wiring. Anyone know what it's for? Diagnostics?
Lovbyts
It's just a cheap easy way to run wiring with a plug. My new Kohler jetted tup uses the same set up for its switch button to the pump. It works fine for low voltage.
[This message has been edited by Paul H. (edited December 28, 1999).]
Lovbyts
I don't remember. I thought it was hooked up to the power anntena? Do you have a power anntena?
G
Discussion Starter · #6 ·
Yeah I found it next to the power antenna. Not connected to the antenna in anyway. It lead to who knows where?
1 - 6 of 6 Posts
