1 - 4 of 4 Posts
what does a rev limiter do and how could it be useful?
14.1 @ 100mph N/A
A rev limiter makes your rpm's hover at a certain spot when the gas is pressed to the floor. You already have one at approx. 7300rpm.
Booooossstt
the rev limiter is set wherever the factory wishes and dependent on system it could for instance cut off fuel once you go past that specified RPM the goodness behind this is so you dont over rev your engine and blow it up. you start gettin to far up in rpms and you will start shootin pieces off of everything.
sean
Discussion Starter #4
thanx
thanx for the info guys
1 - 4 of 4 Posts
