1 - 2 of 2 Posts
i hit a curb extremely hard and ruined a rim in the rear. Ever since i've been hearing a squeaking noise and people tell me that my wheel rotates lopsided.
what do i need to replace or do? the dealer said it might be the hub or something but they wanted $80 just to check.
anyone have any ideas? and how much to replace or fix?
thanks
$80 check out
Check the wheel too! Pull the wheel off and roll it down the driveway.
While you have the wheel off , check the hub and rotor for obvious damage.
I know $80 is alot, but chances are you damaged the hub, bearing, or more likely bent the control arm , and it could get really expensive if you drive around with it like that.:eek:
Take it in to have it inspected & repaired, and plan on spending around $450.00
If you are mechanically inclined I would recommend buying the manual and tearing that assembly apart and looking for damage.
1 - 2 of 2 Posts
