1 - 9 of 9 Posts
Need MORE $$!
1995 Dodge Stealth TT
Hi,
The Anti-Lock indicator keeps coming on in my 95 Stealth TT (38k miles) and I don't have the time right now to troubleshoot it.
I do have a scan tool that I purchased from BlackStealth, if I can use it to diagnose the issue...??
The AL light comes on and blinks 2x, then shuts off, when the ignition is on, but then comes on again while driving, which seems to indicate a wheel speed sensor issue.
I have read many of the threads on the topic and it seems that most recommend pulling the fuse and the bulb in the cluster.
I've tried pulling the fuse under the hood, but it doesn't seem to want to be removed after almost 27 years...
Any trick to this?
Alternative plan:
How tough is it to remove/clean the wheel sensors, I haven't seen a thread on the process, just the fact it should be done occasionally.
Thanks in advance for any info,
John
BC3S
'95 RT/TT
the fuse is held in by bolts on both sides underneath.
the ABS on these cars is garbage. pull the fuse. when you have time & $, get the abs delete kit and remove all the components from your car.
side note: post some pics of your car plz
Need MORE $$!
Discussion Starter · #3 ·
Thanks, I'll get that fuse pulled... where did you get the ABS delete kit?
Photos as requested:
BC3S
'95 RT/TT
holy fuck thats a beauty omg
delete kit you can get from 3sx or STM (i got mine from 3sx)
or order the prop valve from mitsu and make your own lines
Need MORE $$!
Discussion Starter · #5 ·
Thanks, it's been a work in progress for 25 years, at this point.
Can I just leave the pump and tubing in place and remove the fuse?
There must be a prop valve built into the system separate from the pump, correct?
Thanks,
John
BC3S
'95 RT/TT
Thanks,
John
stunning man, well done.
yea you can leave everything in place for now, just the pump won't activate. the prop valve is on the firewall, you will need the non-abs one once you get rid of those lines (if you do).
Need MORE $$!
Discussion Starter · #8 ·
Fuse and cluster bulb removed...
Thanks for your help,
John
Lovbyts
I agree, beautiful, clean and everything very neat. Mine has been a project for 25 years also but still looks like a project for the most part. lol
1 - 9 of 9 Posts
