1 - 5 of 5 Posts
Well I just found out that my license is suspended until next year so I'm planning to do a rebuild over the winter, I was wondering where I can get a "rebuild kit" ie: gaskets, rings, bearings, possibly new cams, lifters, etc...I have a 93 ES NA
I am also doing a complete rebuild of my engine.
You can purchase a head kit from your local Mitsubishi dealer.
The kit consists of everything you need to rebuild the heads.
Send the heads and head kit to a reputable automotive machine shop for rebuilding. Cost should be between 400.00 to 500.00
for the kit (200.00 and the machining 200.-300.00)
You should also rebuild the bottom end of the engine.
You will need to replace the following items;
1) pistons
2) piston rings
3) rod bearings
4) main bearings
5) oil pump
Total cost for the do it your selfer such as myself is about 1000.00
Be sure to purchase a service manual if you don't already have one. It is a must have item.
Good luck!
if you plan and infusing more HP, you should consider replacing the stock clutch.
Best regards, GTMAN
anyone?
Come on......Anyone, I'd hate to have to go to the dealer and buy all of these separately
Wizard of NOS
Call Sunrise Mitsubishi @ 1-800-244-0047 they give 3SI members a 25% discount! These guys should drop your cost a bit, just shop around and compare prices, youve got all winter :D
1 - 5 of 5 Posts
