1 - 5 of 5 Posts
I've read through old posts, and have checked the following:
I've pulled the switch and manually tried to flip the plastic engagement piece on the right hand side of the hole (very far back) up and down, no luck. My switch doesn't look like it's broken, either (it's metal on both sides..I've heard they were plastic earlier).
I've opened my fusebox and checked the fuses, but I don't think it's this since my dash lights work. (They all checked out okay)
Beyond that I'm not too sure what to do..can someone please help?
Thanks,
aeonstorm
Lost Soul
Flip it on then leave it on and see if it makes a noise or not.
-Jeff
C
Guest
Its probably the wiper motor itself, I had the same problem in my 94' 3000GT.
Try checking for voltage at the wiper motor itself, you'll have the remove the plastic cover on the inside side of the hatch. If you get voltage its the motor.
if you need my old wiper motor from my sl let me know...free of course. i took it out to clean up the look of the car.
Discussion Starter #5
That would be..
You're too nice...
I have to figure out how to test the motor first =(
1 - 5 of 5 Posts
