I used a flat head to remove mine. You are going to need new clips.
Thanks DestroyerI used a flat head to remove mine. You are going to need new clips.
You guys are awesome. The video helps a lot. I like how the first thing he says is not to do it.Watch this:
Hey Destroyer I got the bottom off without a problem, and the piece is still straight. Do you know if the top piece is removed in the same manner?I used a flat head to remove mine. You are going to need new clips.
Joe has a video removing the top piece as well. I slipped a trim tool under the top piece and pryed it up. I broke almost every clip but it doesnt matter since the clips are cheap and easy to replace.Hey Destroyer I got the bottom off without a problem, and the piece is still straight. Do you know if the top piece is removed in the same manner?
